Radio won’t turn on
Radio won’t turn on
Postby timdonald » Tue Dec 05, 2017 4:26 pm
Hi,
Today my Transit Custom had a very low battery and wouldn’t start. I left it for a bit and tried again and it did start so took it for a drive to charge things up (it had been standing for a few weeks unused). Seems fine now but the radio just shows the time and date like it has been reset and it won’t turn on or respond to any buttons. It does however connect to my phone via bluetooth. It is a 2014 Custom Limited. Does anybody have any ideas of what might be wrong? Thanks.
timdonald
Re: Radio won’t turn on
Postby timdonald » Wed Dec 06, 2017 3:14 pm
In case it helps anyone else, I pulled the audio fuse to power cycle the radio and now it all works fine again. Must have got stuck with the low battery power but all good now.
timdonald
Postby Altransit » Wed Dec 06, 2017 5:21 pm
Ah, the old "turn it off and turn it on again" routine :lol:
Glad you're sorted 8) 8)
Postby Camper van warehouse » Wed Nov 28, 2018 1:14 pm
Hi
I have the same problem, jump started van, radio show date and time but nothing else, have looked at the fuse and it was ok but have changed it anyway and still nothing, any ideas??
Postby cycleguy » Thu Jan 17, 2019 4:23 pm
I have the same problem on my 2017 can anyone tell what fuse and where to find it cheers
cycleguy
Postby cycleguy » Thu Jan 17, 2019 6:54 pm
All sorted just disconnected the battery for 5 mins
cycleguy
Postby Damonh1823 » Fri Apr 12, 2024 12:51 am
I have the same problem with mine after battery dying tried everything took battery leads off put them both together even gone as far as to take every fuse out nothing still the same this is the second time it’s happened first time took all fuses out and locked van up started it in the morning it worked this time it’s not having it
Damonh1823
Return to Transit Custom
