spare tyre carrier removal
Postby Proper1 » Fri Feb 02, 2018 8:13 pm
Hi can anybody help i wound up the spare tyre winch on my transit custom 2014 without a tyre on it as I had just changed a puncture and was going straight for a replacement tyre as I took the side wall out. Now the tyre winch is very stiff and the wire will not drop down to get spare back on ,I think that wire has come of pulley system when wound up with no weight on it .been online and it looks like a replacement is needed .does anyone know how to remove the tyre winch assembly?
Proper1
Re: spare tyre carrier removal
Postby andyboness1 » Sat Feb 03, 2018 8:00 am
Un-clip cable housing from underneath, drill or grind 4 rivets out inside van, it will then lift out, pretty straightforward.
andyboness1
Postby Frag » Sat Feb 03, 2018 10:32 am
Until it's had a ply lining,or been fibreglassed out as a fridge van etc.... :?
Frag
Ford Technician
Postby Proper1 » Sat Feb 03, 2018 7:01 pm
Hi Andy
thanks for the reply ,thought that's what I would have to do .will I be able to screw the replacement in place with self drilling screws or will it need to have rivits?
Proper1
Postby andyboness1 » Sun Feb 04, 2018 12:02 pm
Rivets really, holes a bit too big really.
andyboness1
Postby andz327 » Sun Feb 04, 2018 2:20 pm
Have you tried winding and unwinding with weight/somebody pulling on the cable
andz327
Postby Deuceduck » Tue Feb 27, 2018 10:49 am
Hi there people . I have a transit connect 2006 . I have a question about the spare wheel carrier . Under my van i have all the cable and mechanism. But the hook bit that holds the wheel up is missing . Can I just buy that part or do you reckon I have to buy the complete spare wheel carrier part ? .
Deuceduck
Postby Big Bank » Sat Sep 22, 2018 12:11 pm
Lots of people with the same problem. Has someone got a good solution to holding the spare wheel in place rather than buying a complete new mechanism for £79? Or someone selling one that is not all rusted like I see in ebay from Germany for "just €60"?
Big Bank
Postby DIY-doughnut » Fri Nov 12, 2021 2:56 pm
My mates been using this for a year to attach their spare wheel to the bottom of their van and it's worked well - £20 for 2
https://www.toolstation.com/ladder-roof ... mps/p27255
DIY-doughnut
Return to Transit Custom
