Hi, I am having an issue with ford transit custom 2.2 2014 - The engine light come up, i lost power. After the scan there are 3 problems P0046,P0047,P0048 which comes to the same stuff. I want to check the boost pressure sensor but I don't know ( and I cant find any details on internet abut this) where is it, where it is located ? I found one website which recommended to follow the process as follows:
Inspect the turbo/super charger system with close attention to the solenoid valve and waste gate (could be be inoperative or stuck)
Inspect the wiring on the boost sensor and related wiring for loose connections, damaged wiring, or faulty sensor
Check the boost pressure during operation and driving for normal range of 9 to 14 PSI pressure (ensures that pressures is not erratic or too high)
Inspect the turbo charger for damaged blades, wobbly shaft rotation, worn bearings, oil leaks into turbo boost side, and correct control valve or waste gate operation
My father mechanic said that few things on this doesn't make sense... As I am not mechanic I cant say anything and that's why I register here to check with you guys.
Definitely I would like to know where is this boost sensor located as I didn't find any pictures showing it.
Please let me know if you know anything on this ?
