Transit custom euro 5 tow bar and wiring kit
Postby loot » Fri Sep 14, 2018 9:23 pm
Right chaps I've had a quick look but could do with a heads up.
I'm looking at a witter tow bar that detaches for 200gbp they range from 230 to 400 for the same or cheaper for Chinese ones :-).
It is the swan neck type.
Also I'm looking at factory fitting electrics, 190 genuine for a 13 pin kit and I'll use a 7 pin adapter for trailer I guess and without for caravan if the need arises.
So just shy of 400 for a real tow bar.
Unless someone can suggest a cheaper alternative or has 1 knocking about?
I have ids and can activate tow bar.
I haven't looked or don't know if our where I may have part loom or whatever or nothing at all of an existing loom?
Ids map here
loot
Re: Transit custom euro 5 tow bar and wiring kit
Postby bambi mk 1 » Fri Sep 14, 2018 9:59 pm
Give these a try Loot http://mccabetowbars.ie/product/ford-tr ... ds-towbar/ They do delivery to UK and I think big price includes fitting which you dont need.Their towbars are stamped for insurance :wink:
Theres the good guys,theres the bad guys but there only ever be one SPEED GUY
bambi mk 1
Postby johnt33 » Fri Sep 14, 2018 10:17 pm
https://rover.ebay.com/rover/0/0/0?mpre ... 1667781784
Don't know if this is of any use. I put a tow trust bar on mine but about the same price as the witter bar.
johnt33
Postby loot » Fri Sep 14, 2018 10:28 pm
Cheers both, this 1 is a witter and I can pick it up locally tomorrow, the wiring I was not sure if genuine was the way to go, more info needed.
I can get cheaper but it is no name but I'd rather get 1i know, but cheaper if possible Lol.
Ids map here
loot
Postby johnt33 » Sat Sep 15, 2018 12:07 am
If it helps, I fitted an ECS dedicated loom and activated it with Forscan, all seems to work well. Only downside was the wiring was as expensive as the tow bar. Two connectors in the passenger footwell area for road lights but I have not yet connected the extra bit for the fridge in the caravan.
johnt33
Postby loot » Sat Sep 15, 2018 1:09 am
Ok thanks I'll have a look :-)
Ids map here
loot
Postby Diesel Jones » Tue Sep 18, 2018 8:06 am
Hello Loot,
Witter detachable swan neck towbar F162Q £272.69 13 pin vehicle specific electrics 29060534 with 3 wire extension 22400512 £163.20 13 to 7 pin adapter MP601B £9.80
Includes VAT and delivery to most of UK mainland, all in stock.
Diesel Jones
Registered Trader
Registered Trader
Postby loot » Tue Sep 18, 2018 8:53 am
Hi Thanks :D
Ids map here
loot
Return to Transit Custom
