bigjohnthomas wrote:Your 1st vid linki don't work boss
Are you hitting it hard enough?
Big copper ommer and spank it's monkey
Brains_transit wrote:The first post always gets locked so it can't get changed at a later date
Punto443 wrote:Don’t think I’ve ever seen that prob before?
Try a bit of heat?
That's the next step i think, weird one isn't it, just concerned that the bearing will get damaged with heat !!!
Cheers
And transits have been that design since I can remember.
bigjohnthomas wrote:bolt the hub back on
smack its arse hard
and rip its head off
https://www.thorhammer.com/hammers/classic.html
bigjohnthomas wrote:If you bolt it back on then it's solid when you twat the driveshaft back
