P0299 underboost fault code
Postby glenandemm » Tue Sep 18, 2018 4:05 pm
Cruising along today engine service now came on and van went into a limp mode, with my basic fault code reader it came up turbocharger underboost p0299 fault code, I’ve checked the wastegate actuator rod is moving freely and can’t see any obvious leaks.
I’ve since cleared the fault and driven it 5-6 miles with no issues since.
Anything to look for or to check?
glenandemm
Re: P0299 underboost fault code
Postby loot » Tue Sep 18, 2018 10:21 pm
I thought all transit customs had a vnt? And that means the actuator shouldn't move freely because it is a geared servo motor.
Ids map here
loot
Postby glenandemm » Wed Sep 19, 2018 8:55 am
Your correct pal they are electronically controlled but the mechanism with the rod attached gets stiff and sticks, to check they’re free you just remove the circlip and slide the rod off the electronic actuator then you can see if the rod and mech are freely moving!
glenandemm
Postby loot » Wed Sep 19, 2018 9:11 am
Yes :D
So, under boost will be either, the vnt actuator, split somewhere or map sensor fault or not reading correct.
Might expect other fault codes though for vnt actuator normally over boost.
Maybe live data will help.
Ids map here
loot
Postby glenandemm » Thu Sep 20, 2018 7:28 am
Cheers pal, I’ve bought a elm lead and downloaded forscan so gonna see what’s being shown in parameters, vans not missed a beat since though!
glenandemm
Postby Andymac365 » Wed Feb 10, 2021 10:25 pm
Did this yet sorted?
Andymac365
Postby glenandemm » Tue Feb 16, 2021 10:37 pm
Never came back pal strangely enough!
I never did anything other than undo the pin and make sure actuator rod was free moving
glenandemm
Return to Transit Custom
