Feeling blu
Feeling blu
Postby loot » Sun Sep 23, 2018 2:38 pm
Obvious answer which I told him was take it back.
He's just bought a 17 plate custom 2.0 130ps e6 adblu.
He's had it literally days and the display shows something likeadblu systen fault in 470 miles no engine start. So he bought 10l of adblu and put that in, Same, started pouring the next lot in but after a small amount it was coming out of the spout.
Warning still there.
I've read that they take 21 litres and will last about 6k miles.
But given that he only got 10.5l in I am going to say that there's a problem somewhere with wiring or doser or whatever, and given the speed at which the fault has come up, I'm going to say that potentially it is likely that the garage he bought it from already knew it was faulty, and just cleared the code before selling it?
I need to ask though, ordinarily do you fill and go? Or is there a secret ritual you need to perform after filling it to clear any warnings(seems stupid and doubtful to me :()
He bought it from the same dealer I've had fun with.
I believe there may be software updates but etis shows no recalls, and if I believe my theory about them already knowing about the fault then I have to assume that they had already tried everything before clearing it and flogging it.
But if that isn't the case it'll get sorted when he takes it back.
Also the van is 11 months old, anyone tell me how a van can get part exchanged at only 11 months? Does that happen if they aren't a lemon?
Bloody Ford :P
Ids map here
loot
Re: Feeling blu
Postby Mikey msrt » Sun Sep 23, 2018 5:47 pm
I’ve had that msg come up a few times and Constantly get filter clogged drive to clean but after taking it on the motorway to active the cleaning process it all goes away.
Get him to give it a good run and see if it goes away
Mikey msrt
Re: Feeling blu
Postby loot » Sun Sep 23, 2018 6:13 pm
Ok cheers mikey
Ids map here
loot
Re: Feeling blu
Postby loot » Sun Sep 23, 2018 8:10 pm
He's done the motorway but it hasn't cleared.
Ids map here
loot
Re: Feeling blu
Postby bigjohnthomas » Sun Sep 23, 2018 8:44 pm
Bloody ford :x
bigjohnthomas
Re: Feeling blu
Postby loot » Sun Sep 23, 2018 8:56 pm
Bloody noisy euro 6 junk rarararara like a fooking Land rover 1 series with a broken spark plug :x but less reliable I'll wager, and no welligogs or tweed flatcap in sight to console myself :cry:
Ids map here
loot
Re: Feeling blu
Postby bigjohnthomas » Sun Sep 23, 2018 9:04 pm
We have tree hugging hippy ass holes and climate change Nazis to thank for that :x
bigjohnthomas
Re: Feeling blu
Postby p2thed » Mon Sep 24, 2018 7:36 pm
Do you know if any codes were logged. Ive changed injectors and egr valves on the new euro 6 engines as these are the most common to fail on the custom and bring the light on.pretty much any sensor going down will bring in an adblue light in these even a clutch pedal switch sets an adblue nonstart count down.
p2thed
Re: Feeling blu
Postby loot » Mon Sep 24, 2018 7:55 pm
Just got a text off him saying the van is fixed and it was a stuck nox sensor.
Ids map here
loot
Re: Feeling blu
Postby p2thed » Mon Sep 24, 2018 7:57 pm
:D
p2thed
Return to Transit Custom
