Ford transit custom
Ford transit custom
Postby brianbarrett61 » Sun Sep 23, 2018 3:03 pm
I have a Ford transit custom 2.2 .155psi 64 Reg problem with fuel tank sencer unit showing zero and Cutting Out like there is no Diesel But there is half a tank of Diesel has anybody had this problem before Help please
brianbarrett61
Re: Ford transit custom
Postby p2thed » Mon Sep 24, 2018 7:30 pm
Tank unit most likley at fault,chaged a couple for the fault that you are describing
p2thed
Postby brianbarrett61 » Mon Sep 24, 2018 8:35 pm
p2thed wrote:Tank unit most likley at fault,chaged a couple for the fault that you are describing
. Just change it two day at the moment everything was good thank you for your Reply
brianbarrett61
Return to Transit Custom
