Whistling belt /pulleys
Postby Custom155 » Fri Sep 28, 2018 5:05 pm
Hi,
My 2014 155hp Limited 110k miles Tourneo has developed a whistling noise that appears to be coming from the belt / pulley area. Disappears a bit (and sometimes completely under load) and turning the a/c on or off makes no difference. The serpentine belt was replaced 6000 miles ago with a genuine Ford belt. There’s no warning lights on the dash. Had a feel of the belts and nothing appears to be loose or hanging off. Any ideas?
Cheers, James.
Custom155
Re: Whistling belt /pulleys
Postby Custom155 » Fri Sep 28, 2018 7:21 pm
Hi,
Doing a bit of digging online and it seems to throw up the serpentine belt tensioner as a possible culprit.. Will keep looking. Anyone changed one of these? Hard to do?
James.
Custom155
Postby Custom155 » Fri Nov 09, 2018 5:14 pm
Hi,
Turned out to be the damped crankshaft pulley beginning to separate. Genuine one fitted at the local garage so back to a quiet engine again. I mean Transit quiet obviously...
Cheers, James.
Custom155
Return to Transit Custom
