Rear light wiring
Rear light wiring
Postby ruffpuffjunior » Tue Oct 02, 2018 12:36 pm
Hi guys,
Anyone could advise which color of the rear light cable connects to which bulb?
I need to connect parking camera to reverse light.
Theres two green- brown
Green-violet
Green-white
Violet-orange
And black which is ground i assume.
Many thanks
ruffpuffjunior
Re: Rear light wiring
Postby loot » Wed Oct 03, 2018 1:28 pm
Grey /brown, that's according to my trailer module diagram.
Best way to find out though is usually to remove the cluster and follow the middle pin to where it goes into the connector. Has always been quite easy to do, otherwise unplug the connector, with a multi tester put black lead to the black cable you think is ground. and with only reverse gear and ignition you should only see power at the reverse pin.
Note that I think these are reverse polarity.
Ids map here
loot
Return to Transit Custom
