DPF Problems
DPF Problems
Postby chrisdainty » Tue Oct 02, 2018 3:41 pm
HI I have 2013 transit custom Eco-Tec . It will not perform a regen and engine management light has came on and in limp mode. It is displaying the following fault codes P1708 , P2463 and P246C. I have tried carrying out a static Regen and it fails at 60%. Any ideas how I can fix this .
Cheers
chrisdainty
Re: DPF Problems
Postby loot » Wed Oct 03, 2018 10:23 am
P1708 Clutch switch (or accelerator switch came up)
P2463 Diesel Particulate Filter Restriction - Soot Accumulation
P246C Diesel Particulate filter restriction - Forced Limited Power
Probably want to get it on live data and check the clutch, sensors and other readings out.
Ids map here
loot
Re: DPF Problems
Postby 114whytegoods » Wed Oct 10, 2018 8:22 pm
Check the fuel vaporizer and small fuel pump that feeds it
114whytegoods
Return to Transit Custom
