Anyone recommend diagnostic tool do dpf regen?
Postby yelsac » Fri Oct 05, 2018 6:53 pm
Hi
As per subject title- Can anyone recommend a diagnostic tool that will definately do a forced regeneration on the diesel particulate filter on a 2014 Transit Custom?
I know the Autel ds808 does but its over £600. I Just wanted to see if anyone had any joy with something cheaper!
I'm asking because I do alot of short journeys, I have constant problems with the dpf as I live on an island with no motorway to be able to do a normal regen.
Any recommendations will be much appreciated
thanks
Yelsac
yelsac
Re: Anyone recommend diagnostic tool do dpf regen?
Postby loot » Fri Oct 05, 2018 7:39 pm
My 2015 custom does short journeys, it still regens even when I'm just driving along 30mph and in mcds drive thru our anywhere :shock:
I hear it about once a month the exhaust sounds hollow.
I have Ford ids clone which will do most things, you'll need 1 that has v96 onwards natively with it though.
07 350 170ps
Ids map here
loot
Postby loot » Fri Oct 05, 2018 7:40 pm
No idea if forscan does it.
07 350 170ps
Ids map here
loot
Postby karl » Fri Oct 05, 2018 8:26 pm
yelsac wrote:Hi
thanks
Yelsac
i was told the other day if you keep getting dpf faults then their is another issue with the van causing the dpf faults.because even at low mileage around town it should re gen its self :( ,But am not convinced on this advice
karl
Tranny Lover!!!
Postby Mike » Fri Oct 05, 2018 8:30 pm
karl wrote:even at low mileage around town it should re gen its self :( ,But am not convinced on this advice
My MK7, both Customs and my Connect have done regens in normal use around town, villages etc. Never had a def issue with any of them. I do ignore the shift light and use sensible revs through the mid gears though.
Mike
Wind up merchant!
Postby glenandemm » Tue Oct 09, 2018 2:28 pm
https://www.ebay.co.uk/itm/New-Modified ... 2749.l2649
i bought this elm327 and downloaded forscan software, you can do a static regen using that in service settings mine took about 40 mins to do, you can check soot loads before and after in parameters too.
worth getting your dpf vaporisor checked or whatever its called, i believe they are commonly faulty stopping a regen from working!
glenandemm
Postby yelsac » Tue Oct 09, 2018 5:38 pm
glenandemm wrote:https://www.ebay.co.uk/itm/New-Modified-ELM327-USB-Ford-Elmconfig-Focccus-Forscan-Focus-Smax-Mondeo-Kuga/223097947771?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
Thanks for the info.
Yes I had a new vaprorisor fitted about 6 months ago, but still doesn't seem to do regen on its own GGGrrrrr. I think its because I live on the IOW & most of the time all I do is relatively short journeys.
With regards to this forscan software I've never heard of that before,so you just download the software onto the elm327 is that right? How much does it cost for the software?
thanks again
yelsac
Postby glenandemm » Tue Oct 09, 2018 9:26 pm
The software is free pal, once you get the lead follow the instructions it’s simple enough to do, its great once its set up!
glenandemm
Postby yelsac » Tue Oct 09, 2018 10:26 pm
glenandemm wrote:The software is free pal, once you get the lead follow the instructions it’s simple enough to do, its great once its set up!
Cheers mate
yelsac
Postby dumper » Wed Oct 10, 2018 5:31 pm
thanks again
Will this work on a mk8 cheers
Postby 114whytegoods » Wed Oct 10, 2018 8:20 pm
Hi had same issue even using a diagnostic tool my custom wouldn't do a regeneration turned out to be fuel vaporizer. Have you checked the small fuel pump that feeds the vaporizer? And aso the wiring.
114whytegoods
Postby Dazza007 » Sun Dec 30, 2018 8:48 pm
Can anyone tell me where the vapouriser is located on a 2.2 fwd euro 5?
Dazza007
Postby bambi mk 1 » Sun Dec 30, 2018 9:08 pm
Dazza007 wrote:Can anyone tell me where the vapouriser is located on a 2.2 fwd euro 5?
Your hard work man ,read the last post posting.php?mode=quote&f=5&p=1622045
bambi mk 1
Postby Dazza007 » Sun Dec 30, 2018 10:06 pm
Soz bud i somehow missed that post. Cheers.
Dazza007
Return to Transit Custom
cron
