help transit custom 2018 headlight
Postby samobst » Fri Oct 05, 2018 7:03 pm
hi can anyone help me please I need to replace both headlights on my custom 2018. the part code on the lights is JK21-13W030-AF I can not seem to find any all i can find is light with the code starting bk21 which i think are from the 2017 models. they look the same but will they fit???
I went into the back of someone and snapped the bracket on mine.
samobst
Re: help transit custom 2018 headlight
Postby loot » Fri Oct 05, 2018 7:13 pm
Nearly everything on my 2015 plate custom is bk21-
To i'll say most likely that the 1 you saw will be the earlier shape headlight and they aren't compatible :(
Ids map here
loot
Postby Altransit » Fri Oct 05, 2018 9:51 pm
Don't the 2018 lights have integral LED running lights :idea:
Even if the earlier ones fit, they possibly wouldn't function the same, so far as the BCM is concerned :?
Postby loot » Fri Oct 05, 2018 10:06 pm
Totally different lights anyway :(
Lights, bonnet, wings, bumper etc probably front slam panel etc and also the sliding door rails are different.
I like the drl in the headlights though 8)
Ids map here
loot
Postby samobst » Fri Oct 05, 2018 10:09 pm
cheers for the replys just can't find anywhere selling them! if emailed ford to see if they have any
samobst
Return to Transit Custom
