Wet seat belts
Wet seat belts
Postby Trendy Dave » Mon Oct 15, 2018 12:41 pm
I've had my 2015 custom a few months now, just recently since the rain has returned i've been suffering with wet seat belts !
Has anyone else had the same problem ?
Trendy Dave
Re: Wet seat belts
Postby Frag » Mon Oct 15, 2018 2:43 pm
I'm guessing you have a roof rack or bars fitted,and it's not been sealed right where bolts go into roof captives,
You need to sort this because water is highly likely to track down loom into the bcmii,causing you a bigger issue than wet seat belts.
Frag
Ford Technician
Re: Wet seat belts
Postby Trendy Dave » Mon Oct 15, 2018 3:00 pm
Ah, no I haven't but it has had a roofrack removed !
I need to reseal the holes where it was bolted then....
Cheers
Trendy Dave
Re: Wet seat belts
Postby jinx » Mon Oct 15, 2018 8:52 pm
Trendy Dave wrote:Ah, no I haven't but it has had a roofrack removed !
Cheers
I had this problem , not wet seatbelts but water leaking in the rear so i unscrewed all the blanks on the roof and put clear silicone in each threaded hole then replaced the blanks and bone dry now :D
jinx
Re: Wet seat belts
Postby Trendy Dave » Mon Oct 15, 2018 9:05 pm
Cheers
cheers jinx, i had a look earlier, there are just stainless socket caps with a washer in each threaded hole, no sealant in any of them, will seal them all asap
Trendy Dave
Return to Transit Custom
