ford transit custom dpf regeneration keeps aborting
Re: ford transit custom dpf regeneration keeps aborting
Postby Altransit » Sun Dec 02, 2018 11:18 pm
I will always pull a fuse to check it, and even if it looks OK, I will substitute it with a known working fuse, or a new one out of the box. Like bulbs, sometimes they look OK, but the filament (or wire) can have a small crack in it. :)
Postby pete1 » Sun Dec 02, 2018 11:28 pm
Fantastic
im getting a good feeling about this due to the fact that most of the parts related to problems with dpfs are on this fuse.
what odds do you give :D
pete1
Postby pete1 » Sun Dec 02, 2018 11:31 pm
Altransit wrote:I will always pull a fuse to check it, and even if it looks OK, I will substitute it with a known working fuse, or a new one out of the box. Like bulbs, sometimes they look OK, but the filament (or wire) can have a small crack in it. :)
Thanks for that i will take that on board.
have you come across this problem before??
pete1
Postby Altransit » Sun Dec 02, 2018 11:35 pm
No sorry, I'm not a professional vehicle mechanic, so my advice is purely generic, but I would always trust the word of many of the experienced mechanics on here, and Bambi is one of that particular club :D
Postby pete1 » Sun Dec 02, 2018 11:39 pm
Altransit wrote:
id get thanks for that i will take that on board.
Thanks for that
and yes i did get that impression from his responses :D
pete1
Postby Altransit » Sun Dec 02, 2018 11:42 pm
BTW, I'll move this to the Custom section, as it isn't a Mk8 :wink:
Postby pete1 » Mon Dec 03, 2018 9:19 pm
All fuses checked and all working.
Any ideas???
pete1
Postby Frag » Mon Dec 03, 2018 10:11 pm
There's a fair chance the vaporiser is blocked,the port where fuel is sprayed into exhaust fills with carbon then diesel cannot be injected.Needs this checking,we use a mityvac.
Other likely suspect is a thermostat issue,causing coolant to not reach the required temp to initialise a regen.
Frag
Ford Technician
Postby pete1 » Mon Dec 03, 2018 11:09 pm
Many thanks again
My engine temp is really low atm Its barely getting above 60 and that's after travelling over 6 miles.Basically the needle is just staying flat at the lowest reading
Could this be the problem
pete1
Postby Frag » Tue Dec 04, 2018 9:52 am
That's definitely not right,and will prevent regens,
Guage should be on middle mark once warm,I'd put a thermostat in.
You may still have a blocked vaporiser,but need to fix coolant issue first.
If by that point the soot load is above 150%,it won't do a regen itself and will need a static one.
Frag
Ford Technician
Postby deno 1 » Wed Dec 05, 2018 11:34 pm
Yep sounds like a blocked vaporiser to me also ..... had the same thing with mine some time ago....
deno 1
Postby ake » Thu Dec 06, 2018 9:14 pm
Blocked/failed vapourisers seem to be the most common failure of the Transit DPF
We have never had to replace a dpf or use a ‘cleaning’ service
Postby loot » Fri Dec 07, 2018 11:08 am
It's like all the people who have maf fault and replace the maf to no effect.
Also can I note that I can hear my dpf regeneration and I can hear it on tick over, the exhaust sounds throaty, so I propose that having the regens aren't overly hard to achieve even with city driving, so would personally look at faulty components first. :wink:
Ids map here
loot
Postby pete1 » Fri Dec 07, 2018 11:21 pm
Firstly many thanks to everyone involved in this thread.
It turned out to be a faulty thermostat that had simply been missed by all the mechanics involved.The mechanic I took it to diagnosed the fault within a few minutes simply by the smell of the van in constant start up mode .
The van now drives better than it has since I bought it and we believe that all my problems including initial egr replacement where linked to the faulty thermostat.
Oh and I now have heaters that work :D
Kind regards pete
pete1
Return to Transit Custom
