Kardaani wrote:I have twin battery in my 2014 custom. Never problems with startbattery, but the second drains flat during a week. Secondary is brand new, OEM Varta and the startbattery same original, but tested to be "great condition". Secondarys Discharge current is about 200mA when parked and doors locked. I dont know is that 200mA ok or not?
By math: 70Ah / 0,2A = 350hours/24h = 14,5days to discharge copletely from 100% to 0%. Main problem with low battery comes when eber wont start heating under 11.8V
Ford manual I have says typical 20mA drain on a parked custom.200mA is too much. Any chargers fitted which may drain it?
"It is recommended that the total Ampere
consumption, in sleep mode, from the auxiliary
battery, does not exceed 100mA. This is because
BMS will not be able to accurately correlate the
battery state of charge. Note there is
approximately 20mA of key off load from existing
Ford fit systems so the additional maximum is
80mA of converter fit system. Any third party
installations should ideally be activated via
Ignition or engine RUN. However, a sleep mode of
100mA is still high and will lead to deep discharge.
The High Performance Deep Cycle AGM batteries
option should be pulled if greater than 5mA in
sleep mode of additionally fitted systems.
Regardless of battery system, it will still be
required to frequently charge when at long periods
of engine off."
