Just wondering how many of you follow the gear shift warning advising you what gear you should be in. I used to, but I found I was always changing back down to a lower gear seconds after being told to change up. OK my fuel consumption may go up but I find the van a lot better and nicer to drive. Is there a way to turn it off completely using the obd or maybe some black magic like pressing pedals like you can do for resetting service lamps and the like.
