Hi All,
Just wondering if anyone has experienced anything similar to me, so yesterday I decided to give my van it’s usual clean nothing out the ordinary, didn’t clean the engine bay or anything. Then later that evening took the van out and 5 minutes down the road ‘engine service now’ pops up on the dash which I thought was weird as ford serviced it less than 5k miles ago. (Van now on 33k miles, 65 plate 2.2 125 trend) so anyway carried on driving not thinking much of it and got to a round about and went to pull away and it wouldn’t go above 2k revs... so the van had gone into limp mode which I thought was weird as it’s never skipped a beat but maybe a coinsedence as I had just cleaned it? Anyway rolling bump started it and the fault cleared and all was normal again and then 5 minutes later it pops back up again so a couple moments later I rolling bump it again and it clears and I carry on my journey and it doesn’t come up again. Went out there this morning checked under the bonnet, looked at all connectors and all looked Fine to the eye. So plugged my scanner in and it showed MAF air flow to high (will attach picture)
Done a little research online and seen a few posts of similar things throwing that same error code and symptoms but with a few different culprits and none actually being the MAF Sensor it self. So just hoping if anyone has experienced something similar if they can shed some light. I’m hoping it was a hiccup but the real test will be tomorrow when I’m off to work again but I have my doubts that this is the end of it.
Many thanks
