If it's the same as the Mk6 & 7, then the threaded holes aren't there on the A pillar
I've needed to fit a grab handle to both of my vans, so I bought a minibus handle, drilled the holes, and fitted threaded rivets, as you can't get to the back of the pillar to fit normal nuts.
Hole drilled, there are two flats on the A pillar in the appropriate place
You need to measure the appropriate distance between holes on the handle
Threaded rivet in place
Rivet tool
Genuine Ford handle from minibus or Tourneo
