bobtol wrote:Hi
Can anyone explain in a step by step how I change settings in central config for newly fitted tow bar. New to FORScan and don’t want to screw things up. Also do I need to download any files for this. Cheers.
Bob. T
I can't explain exactly but essentially you need to do the following. Also, be warned, if you mess it up it can render your vehicle immobile and require it being towed to a Ford garage for a BCM restore!
If in doubt, get Ford to code it. It only takes a half hours labour charge.
If you are keen to have a go read as much info on the FORScan website and watch the tutorials on YouTube first.
1. Go to the FORScan website and follow the instructions to license the software.
2. Connect to your vehicle and open the Central Configuration file.
3. Save a copy of your default settings to your computer. This is a safeguard and allows you to restore it if you get it wrong or your computer crashed half way through.
4. Load the settings for your Main Module but NOT the 'As Built' version as this is in hexadecimal and can easily be mis-configured.
5. Locate the 2 (separate) Towbar options and enable them from the drop-down options.
6. Commit the changes to your vehicle.
7. Reset all DTC error codes power cycling your ignition as instructed before disconnecting from your vehicle and unplugging the adaptor.
These ^ are essentially the steps you would need to take but before you go ahead I can't stress how important it is to read and understand how it works before you make any changes. However, there is a lot of info on the FORScan website in the support section and it's not difficult once you know.
Good luck!
Sent from my CLT-L09 using Tapatalk
