New member here.
I've just bought a 2014 Transit Custom and need to install a leisure battery.
I soon became aware of the dreaded smart alternator issue and followed the advice of this video to determine if whether I have a smart alternator (which I already kinda knew because it's a Euro 5 vehicle)....
https://www.youtube.com/watch?v=X3LDVZAZMII
I drove the van at varying speeds and road conditions for a good 20 minutes and the voltage never dropped below 14.9 volts for the duration of the whole trip.
However, I also went into the local Ford main dealer and asked if my van had a smart alternator - "yes" came the answer.
I then asked whether I had regenerative braking - "no" came the answer.
On the basis of the above points, and upon seeing 'Cider Andy's comments from another post, here:
Cider Andy wrote:Cider Andy wrote:2010 is a Euro4 van. It too has a smart alternator but the split-charging setup does work with a voltage sensing relay - I've fitted one on my own van.
There's a bit of confusion about what a 'smart' alternator is. For the last 15 or 20 years a 'smart' alternator has been around, smart because after starting the engine it gently raises the output voltage irrespective of engine speed to prevent damage to electronic equipment. But a 'smart' alternator these days, introduced to help meet Euro6 emissions standards, forms part of the regenerative braking systems, in conjuntion with on-board ECUs and different battery technologies. It's these vehicles that need battery-to battery charging systems to totally separate the modern vehicle electrical system from the traditional 'leisure' electrical systems.
Can I assume that, although I do have a smart alternator, I can use a split-charge relay in this particular van?
Thank you for reading.
Matt
