Oil warning message
Re: Oil warning message
Postby V184 » Fri Apr 19, 2019 7:21 am
Garysparky wrote:Hi I have a 2016 2.0 custom which I bought new. I had it serviced with an oil change and updates at 16k in August. For the last few weeks the “change engine oil soon” light has been coming on when I start it up. When I phoned ford they said I would need to bring it in for them to look at but probably may needs an oil change! After 8k miles! I used to get 20k between services on my vito. I tried the holding pedals down reset with no success. Anyway I was speaking to a mechanic at a van hire depot the other day and he showed me how to reset it by going into settings where you get the option to cancel the warning. It only says change engine oil soon so I wouldn’t think it is harmful to reset as ford wouldn’t give you this option if it was.
Vitos are a top quality product but i read the other day the latest ones are suffering the same problem as the Custom especially if mostly driven in cities :shock:
V184
Postby dumper » Fri Apr 19, 2019 8:09 am
bambi mk 1 wrote:https://www.thecarexpert.co.uk/new-car-warranty-servicing/ :wink:
So the fisherman is correct so a garage or mechanic has to licensed so you can’t just service it yourself and to be a licensed garage or mechanic do you have to be vat registered and a qualified mechanic can not do it as a cash job on the side
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Postby bprobinson10 » Mon Apr 22, 2019 8:31 pm
I'm also getting this oil replacement msg
Sent from my SM-G950F using Tapatalk
bprobinson10
Return to Transit Custom
