Hi guys.
Got an issue with my van. Basically the brake pad wear warning is permanently on.
The wiring was damaged a few years ago and the local Ford repair was simply to short the wires out conning the system into thinking that pad was always ok.
Fast forward to today, the van is out of warranty and it has started acting up because the wire itself is corroded giving enough resistance that the computers think the pad has gone too low. I would cut the wires back further but that would mean running the risk of damaging the abs sensor wiring now as there's only about an inch of individual wire, that's corroded, exposed after their bodge.
So the question, does anyone have a wiring diagram or know the pinout and which module controls the warning so I can do a better bodge than Ford?
Thanks in advance.
