skeet wrote:Can do but the letter is covered in details of my van so I think you may need your own. Suggest you ask on the 30th?
skeet wrote:Anyone else had a letter?
2018 125 2.0
I havent had any problems with mine.
The letter explains that the fuel is injected into the engine oil to combat emissions.
I guess if this goes wrong you end up with very diluted fuel!
Chrisp74 wrote:Do we think that it actually puts fuel into the oil? Or fuel gets into the oil via the combustion process? ie piston blowby, EGR etc.
No expert but I thought fuel in the oil was a unwanted side effect of using extra fuel during the injection process to combat emissions?
woodbutcherbower wrote:All Euro 6 engines with a DPF end up with a small amount of fuel going into the oil. It's part and parcel of the emissions reduction mechanism and isn't injected deliberately as another poster has asked. The engine has an 'IOLM' (Intelligent Oil Life Monitor) sensor set which monitors the viscosity, theoretically warning the driver when the oil needs changing - hence the 'change engine oil soon' messages you may see on the dashboard monitor. All the software update does is to tweak the sensitivity of these - or that's how my local (very good) main dealer explained it to me. The software update is therefore designed to further reduce the possibility of the oil become too diluted and thus reducing its effectiveness.
Maybe I'm being a cynical old b*****d, but I think that this is Ford secretly admitting that they've f***ed up by claiming that the engine can do 36k between oil changes. Really? Are they serious? I change my oil and filter every 6k and always have done - my old Connect had done 272k at scrappage and the engine still ran like a sewing machine. Everything else had fallen to bits, mind ....![]()
My update was done last week when I was having my 24k change done. The only noticeable thing when I drove it away was that the radio had dumped all of its presets. Battery disconnected for the update maybe?
Kev
Users browsing this forum: Baidu [Spider], Google Adsense [Bot]
