Does anyone have the Circuit diagram for Transit Custom 2013 Power Window circuit. Currently Passenger side works from both driver and passenger side switchers. However Driver side Windows is intermittent, works time to time. Would like check it out.
Just fixed the wire for indicator under mirror same Place as mentioned.
My take on the root cause of my problem! It was the door that got pulled out of my hand by the wind ( reason I ended up on this forum IIRC ) this had stretched the wire then the fatigue of pen and closing.
This is why we ask for a much info as possible with faults because it paints a better picture for diagnosis Frag of course was quite correct as his experience of this is vast.
56 350 2.2 130ps mk7 with 2 side doors 65 290 2.2 125ps custom with 2 side doors 07 350 170ps Ids v86 licence + v86.04 update + xprog here Ids map here
