Hay guys the over day I got engine management light up and the traction control light up on my dash all at the same time. So I took it into the garage and was told I had a fault code of P042F and that the cable that's connects the abs and brake sensors was cut and that is the cable that go's off to the ECU. That's why it saying I have brake warning and NO hill assist on the trip computer. The garage I went to tolled me I was best going straight to ford with this problem witch is worrying me and making me think its a big job ? Dose anyone know what I would be looking at for something like this or can you shed a little bit more light on it if you know what it is and if its a easy or cheap job ?
The P042F witch come on at the same time I was tolled it was EGR fault and could just need cleaning out is that a cheap job to do ? I also asked on fakebook forum not long ago about I could smell fumes in the cab now and again could that be down to that?
Ones I have sorted out them jobs on the van was thinking about removing DPF as I have read its better for the engine I am aware of the complications when it come to MOT but would it be better for the vans health ?
It is a Ford Transit custom 2.2 euro 5
