by Abbadon » Mon Jan 06, 2020 1:39 pm
I had a similar issue - there was a fault with the front-most interior light unit - inside the switch was a bit glitchy, and as a result, somehow, that screwed up all the rest.
I might have some photos somewhere.
Inside that unit, there are some copper tracks, that move the electricity around but also form part of the switching setup. these had all come loose from the surrounding plastic. Once I glued it all back where it should be, all my issues went away.
Id take a look inside each unit and see if anything is all loose and floppy to begin with.
One thing to also try, to see if this might be the cause - try turning each of the ceiling units off fully, with the rest turned on to door activated, and see if any combination makes it all work as it should, this may point to the unit that is turned fully off, as being the one with an issue inside.
