65 plate, 2.2LWB LTD Custom 155bhp
bit of a novice on servicing my own vehicle but thought i would give it a go last year!
Changed my oil and filter, found this quite easy but would have been easier with a oil filter removal tool.
air filter was ok too.
fuel filter! this wasnt so easy, bought the fuel filter tool amd took it off ok , but refitting wasnt as straight fwd, had a nightmare trying to push the filter up into housing and then twist back into position, took me ages!! i also filled the filter housing with fuel prior to fitting, (didnt want to get air in the system) is this necessary? as ive just watched a video on you tube from haynes and they didnt but they did turn the ignition on and off a few times before starting
any tips on refitting fuel filter much appreciated
how often should i change oil & Filter? fuel filter? and air filter?
