crimmp wrote:Thanks. I just found the BEMM document (did not know it existed before) and found the relevant info. Seems like I need to get the kit from a Ford supplier which lets me access that signal directly from under the driver's seat, right next to the vehicle battery. This is actually great news, as it sounds much easier than forking the D+ wire from the alternator myself.
Fred-W wrote:Thanks Dosh 28. that diagram and information was very useful.
Pin 4 - Ignition signal is +12 V protected by a 10A fuse and active at ignition positions 1 and 2.
Dosh28 wrote:Fred-W wrote:Thanks Dosh 28. that diagram and information was very useful.
You're welcome Fred. Yes, positions 1 & 2, so the feed is not on when the engine is cranked.
richbee wrote:Dosh28 wrote:Fred-W wrote:Thanks Dosh 28. that diagram and information was very useful.
So it is active before the engine starts - at position 1, with accessories on? That doesn't sound right?
I thought 'motor on' meant only while the engine is running, otherwise if you just put the key in & turn to position 1 to listen to the radio without starting it, it will drain the main battery to charge the leisure battery.
Dosh28 wrote:richbee wrote:Dosh28 wrote:[quote="Fred-W"]Thanks Dosh 28. that diagram and information was very useful.
yasser wrote:When I used the the socket under the seat i used a small female spade connector, , squashed it a little and then heat shrank it to make sure it was totally insulated from the other pins. It worked fine but it was always nagging on my mind and if anything went wrong, would Ford reject a warrant y claim. So i bought the proper cable and for what it was it was horrendously expensive. It was about £50-55 for a plastic plug with a 3 meter tail. When I sold the van I took everything out and I still have the cable. If anyone is still after the cable I can post all in for £25. Message me.
