by Frag » Thu Mar 26, 2020 12:04 pm
You said you checked fuses,not replaced any...
Replacing,or checking a fuse will not cause this.
Removing one from its correct position,and putting it back in the wrong place will ......
It’s a small normal type fuse 5 amp I think,roughly middle of fuse box extreme left,
It’s on it’s own,but,there are 2 spaces there,put it in the wrong one which is empty,and you’ll get your fault.
It’s fuses 13 and 14 in the passenger fuse box.13 is not used,14 is.
