Hi Guys ,
I need to pick your Brains . My works van is a 2016 transit custom, I hadn't driven it for a few days due to lockdown, and maybe forgot to lock it. The battery became flat reading 4 volts . Cut a long story short I recharged the battery and reinstalled it today. Everything was going good untill I turned the key in the ignition. I was first met with a warning notice stating that Hill Start Assist not available and then High Engine Temperature stop safely. This meant I was prevented from turning the vehicle over . The battery was reading 12.7 v . Is this a fault with the battery or something else ? Many thanks
