Altransit wrote:There is a fan controller bolted to the radiator cowling, this can be faulty (I've had one) or it could be worth checking that the fan is free to turn and isn't partially seized
There are two boxes on radiator cowling. Other contains 50A fuse for fan and other is actually resistor for "low" fan speed. Today i tried to fix HI speed again and noticed that the LOW speed doesnt work anymore. So the fan isnt spinning at all now. Removed the resistor and figured out that the wire on it was burned cut.
It was ok few weeks ago when the fan still spinned LOW speed but it might had some problems all the time. Now i hope this is the main reason for HI speed failure too.
I visited Ford dealer to buy new resistor but its not selled separately. Only comes with whole set of new fan, plastic housing, resistor, wires etc. prised 350€/270£. After that visited few spare part shops but nothing. Then long googling and nothing but some used parts from ebay.
Resistor is made by Bosch and partnumber 3134503095
Any ideas where i could find new one?
