by S60r » Sun Jun 14, 2020 9:25 am
Hi.
It’s certainly not quiet on here.... there are many threads and issues with injectors. Have a good search on here.
I believe I have a fault on my 2018. It drives perfectly 99% of the time but up hill at motorway speeds it will start playing up. All other types of driving are fine. It goes into Ford and they find no faults and declare that it is fine. No warning lights, limp mode or stored codes, very frustrating. As it does it every day.
The way Ford work with their warranty work is not good, I will end up solving it myself probably.
I have had both the 2.2 and the 2.0 and can tell you the 2.2 is not as good. It’s very unrefined and being euro 5 I would avoid it if you are planning to travel into any cities and will keep the vehicle for a few years..... euro 5 will be very unwanted as time goes on.
The issue is restricted to certain build dates and serial numbers of injectors apparently.... it’s all on another thread on here.
Even with the issues, I would go for the newer panther engine over the 2.2.
