Hi Everyone, Just wanted to share a repair tip with you all today! we've had a 2016 custom in last week that wouldn't rev over 2000 rpm but had no warning lights on the dash or fault codes in the ecu! After reading the actual data on the Snap on scanner we've pinned it down to the Fuel temp sensor.. temperature was reading 98 degrees!, if you disconnect the sensor it will default to 40 degrees and allow it to rev past 2000 rpm but its logs a fault code and puts it into limp mode! so a new sensor needs to be fitted. The sensors are only available from Ford at the moment.. Part number 1793886 here's a link to one I found cheaper on Ebay http://rover.ebay.com/rover/1/710-53481 ... 4022902964
Ive done a YouTube video on the repair..hope it help anyone in a similar situation! https://youtu.be/7SzQySNbZEY
