S60r wrote:To close this off...
if you have limp mode type symptoms but with no warning lights... watch your temp gauge... if it flickers up when the limp mode occurs then you have a faulty thermostat.
Ford have a new part that solves the issue...I have had this issue for 7000 miles without any stored fault code and lots of pointless dealer visits.
New thermostat assembly and it drives perfectly again. Remap loaded back on and all is well.
Just want to thank you for taking the time to write the follow-up for this.
I’m currently 2500 miles from home and the van has exactly the same symptoms
It started when I got to Portugal and was driving up a mountain on top gear: suddenly no power at all. Temperature gauge needle jumped up a notch, then I switched to a lower gear and the van got full power again. It happened a couple of times but no fault codes or anything so I thought it might be just some fuel issues.
Now I’m on my way back home and the van started acting up again when I was crossing Spain. Lost the power when climbing up a mountain and this time had trouble getting it going again. Crawled up some more mountains doing 60 km/h and the temp gauge acting up, then I pulled over and found your post.
Gotta see tomorrow if I can find a place to get the thermostat changed somewhere in Valencia. The van still drives OK if I keep it under 105 km/h and have the heater on so I’ll probably just keep going if I can’t get it changed. Still a long a long way to go
