Euro5 remote folding mirrors option with forscan
Postby glenandemm » Sat Jul 11, 2020 12:01 pm
Has anyone recoded they’re bcm for the mirrors to fold in on double press remote?
I’m looking for the coding for forscan if anyone can advise?
glenandemm
Re: Euro5 remote folding mirrors option with forscan
Postby gregd72002 » Sun Jul 12, 2020 10:29 am
Not possible AFAIK. Can do it for you using UCDSYS if you want
gregd72002
Postby glenandemm » Tue Jul 14, 2020 7:26 am
Cheers pal I’ve ordered a UCDS lead, I think there’s a possibility it can be done but you need the line of coding to change the block as it doesn’t give you a word for word option of selecting it like UCDS, once I’ve done it I will reconnect my forscan and see what it says in the line of coding change!
glenandemm
Postby gregd72002 » Fri Jul 17, 2020 8:17 pm
How did it go?
gregd72002
Postby ake » Tue Jul 21, 2020 6:56 am
I’ve tried this on my Euro 6
It gives me the option in the dash menu, but it’s greyed out and can’t be selected
As far as I can make it, it won’t work because the custom doesn’t have door control modules
Postby S60r » Wed Jul 22, 2020 6:21 am
Think I used this on my 2015.....
https://www.vansystem.co.uk/det/2435/Fo ... rror-Loom/
I know you are looking to code this, but for 40 quid this will sort it.... it adds a control module which I guess is missing from the transit.
Worked well on mine but I haven’t added it to my 2018 as I prefer to fold them manually rather than burning the motors out due to the amount of visits I make to the van daily!
S60r
Postby gregd72002 » Thu Jul 23, 2020 8:02 am
The software solution is the factory option. Much better than the loom. It only folds the mirror if you double click the lock button so you are not burning any motors unless your choose to fold them.
Having said that there seem to be no such option for euro6 vans.
gregd72002
Postby glenandemm » Sun Jul 26, 2020 4:21 am
Cheers lads, sorted it with the ucds lead.
I’ve started offering it to anyone local too for £10 if they bring it to me!
Saves anyone buying a lead or not confident going into the settings.
Worlds a treat now
glenandemm
Postby Dan T » Thu Aug 13, 2020 11:36 pm
It’s possible without UCDS.
Direct asbuilt sector edit
Dan T
Postby Fordham1984 » Wed Nov 11, 2020 11:18 pm
Dan T wrote:It’s possible without UCDS.
How?
Fordham1984
Postby Chris1987notts » Sat Mar 04, 2023 11:41 am
How is this possible using UCDS? Does anyone have a step by step guid for a custom 65 plate?
Chris1987notts
Postby Fordfanman » Sat Jun 17, 2023 6:49 pm
I followed these UCDS instructions for my 64 plate:
Fordfanman
Return to Transit Custom
