by smalltownmotion » Mon Apr 26, 2021 7:21 pm
===PCM DTC P0671:00-2F===
Code: P0671 - Cylinder 1 Glow Plug Circuit / Open
Status:
- DTC Present at Time of Request
- Malfunction Indicator Lamp is Off for this DTC
Module: Powertrain Control Module
Freeze Frame :
-GLOBTIM: 206494511 s - Global real time
-TOTDIST: 158073.0 km - Total Distance
-MAINECUV: 11.50 V - Main ECU voltage supply
-OUTTMP: 15 °C - External Temperature From Sensor
-PWR_MODE_KEY: Ignition On - Power Mode Key State
-PWR_MODE_QF: Power Mode OK - Power Mode Quality Factor
-LOAD: 0.00 % - Calculated Load Value
-ECT: 14 °C - Engine coolant temperature
-MAP: 100.0 kPa - Manifold absolute pressure sensor
-RPM: 0 1/min - Engine Revolutions Per Minute
-VSS: 0.0 km/h - Vehicle Speed
-IAT: 15 °C - Intake Air Temperature
-MAF: 0.00 g/s - Mass Air Flow
-TP: 94.12 % - Throttle Position
-RUNTM: 0 s - Time Since Engine Start
-FRP: 100.0 kPa - Fuel Rail Pressure
-EGR_PCT: 0.00 % - Commanded EGR
-BARO: 100.0 kPa - Barometric pressure
-CATEMP11: 63 °C - Catalyst Temperature Bank 1, Sensor 1
-CATEMP12: 63 °C - Catalyst Temperature Bank 1, Sensor 2
-APP_D: 15.29 % - Accelerator Pedal Position D
-APP_E: 15.69 % - Accelerator Pedal Position E
-TAC_PCT: 0.00 % - Commanded Throttle Actuator Control
===END PCM DTC P0671:00-2F===
===PCM DTC P0672:00-2F===
Code: P0672 - Cylinder 2 Glow Plug Circuit / Open
Status:
Freeze Frame :
-GLOBTIM: 201236314 s - Global real time
-TOTDIST: 154233.0 km - Total Distance
-OUTTMP: 19 °C - External Temperature From Sensor
-ECT: 34 °C - Engine coolant temperature
-MAP: 101.0 kPa - Manifold absolute pressure sensor
-IAT: 30 °C - Intake Air Temperature
-FRP: 120.0 kPa - Fuel Rail Pressure
-BARO: 101.0 kPa - Barometric pressure
-APP_D: 23.53 % - Accelerator Pedal Position D
-APP_E: 23.92 % - Accelerator Pedal Position E
===END PCM DTC P0672:00-2F===
===PCM DTC P0674:00-2F===
Code: P0674 - Cylinder 4 Glow Plug Circuit / Open
Status:
Freeze Frame :
-GLOBTIM: 194073369 s - Global real time
-TOTDIST: 149517.0 km - Total Distance
-ECT: 58 °C - Engine coolant temperature
-IAT: 35 °C - Intake Air Temperature
-FRP: 140.0 kPa - Fuel Rail Pressure
-CATEMP11: 102 °C - Catalyst Temperature Bank 1, Sensor 1
-CATEMP12: 126 °C - Catalyst Temperature Bank 1, Sensor 2
===END PCM DTC P0674:00-2F===
===OBDII DTC None===
Successful DTC reading, no error codes found
Module: On Board Diagnostic II
===END OBDII DTC None===
===APIM DTC None===
Module: Accessory Protocol Interface Module
===END APIM DTC None===
===SASM DTC None===
Module: Steering Angle Sensor Module
===END SASM DTC None===
===ABS DTC None===
Module: Antilock braking system
===END ABS DTC None===
===RCM DTC None===
Module: Restraint Control Module
===END RCM DTC None===
===PAM DTC B1B52:14-2F===
Code: B1B52 - Rear Sounder- Park Aid
Additional Fault Symptom:
- Circuit Short To Ground Or Open
Status:
Module: Parking Aid Module
Freeze Frame :
-GLOBTIM: 0 s - Global real time
-TOTDIST: 0.0 km - Total Distance
-INCARTMP: -40 °C - In car temperature
-OUTTMP: -40 °C - External Temperature From Sensor
===END PAM DTC B1B52:14-2F===
===HCM DTC B1C98:13-08===
Code: B1C98 - Left Corner Lamp Circuit
- Circuit Open
Status:
- Previously Set DTC - Not Present at Time of Request
Module: Headlamp Control Module
===END HCM DTC B1C98:13-08===
===BCMii DTC B109A:11-08===
Code: B109A - High Beam Relay
Status:
Module: Body Control Module
===END BCMii DTC B109A:11-08===
===BCMii DTC B1D00:15-48===
Code: B1D00 - Left Low Beam
- Circuit Short To Battery Or Open
Status:
- Test not complete
===END BCMii DTC B1D00:15-48===
===BCMii DTC B1D01:15-48===
Code: B1D01 - Right Low Beam
Status:
- Test not complete
===END BCMii DTC B1D01:15-48===
===BCMii DTC B109F:87-48===
Code: B109F - Intrusion Sensor Module
- Missing Message
Status:
- Test not complete
===END BCMii DTC B109F:87-48===
===BCMii DTC B1D38:16-48===
Code: B1D38 - Front Wiper Motor
- Circuit Voltage Below Threshold
Status:
- Test not complete
===END BCMii DTC B1D38:16-48===
Transit/Tourneo Custom 2012, 2.2L CR TC I4 DSL 125 PS
