Engine catastrophic failure!
Re: Engine catastrophic failure!
Postby Mrcjstone » Fri Apr 30, 2021 4:51 pm
Well the van is ready to be picked up tomorrow! Amazed they have done it so quickly and as I say the Ford service has been fantastic. I was just curious if the new engine would have had the wet belt modified and if so does anyone know what has changed?
Mrcjstone
Postby ghosttt » Wed May 12, 2021 3:07 pm
That was quick!
The belt itself wasn't the issue, it was the oil getting diluted (faulty injectors, I think?) and the belt disintegrating as a result.
ghosttt
Postby Mrcjstone » Wed May 26, 2021 4:33 pm
https://m.youtube.com/watch?v=lJtENVwAEpk
This is a good video. It’s a bit cloak and dagger but as I understand it it is due to the dpf regeneration process. This is ultimately controlled by injectors but can be caused by a few other conditions. My van was mainly used on motorways so the dpf process should have been effective so yes may have been faulty injectors.
Mrcjstone
Postby Mike » Wed May 26, 2021 5:13 pm
He’s saying that current Transits shouldn’t suffer from oil contamination because they use the 5th injector in the dpf?
Mike
Wind up merchant!
Return to Transit Custom
