Battery warning light issue
Postby Destiny Di » Wed Apr 28, 2021 12:15 pm
Van- Custom 290 ECO-TECH 2.2cc 2014 plate. SWB & low roof.
Battery warning light comes on after about 1 mile, same distance every time! and stays on until engine is switched off.
Charging system all working, battery & alternator good and nothing showing up on diagnostics.
Any ideas would be more than welcome
Many thanks
Diane
Destiny Di
Re: Battery warning light issue
Postby p2thed » Thu Apr 29, 2021 12:27 am
are you getting good communication between the pcm and the alternator on the linbus( green wire)??
what are your charging voltages with all loads turned on.??
any fault codes present, normally with an alternator light on it would set a code???
p2thed
Postby Destiny Di » Fri Apr 30, 2021 12:52 pm
Thank you for that input, I will pass it on to my mechanic as it is in the garage right now trying to find the fault.
Many thanks
Destiny Di
Postby L44hul » Mon Mar 14, 2022 2:20 pm
Don’t suppose you got to the bottom of this problem as I have the exact same issue
L44hul
Return to Transit Custom
Users browsing this forum: Google Adsense [Bot], gt53
