Stereo
Stereo
Postby Sparkyg1000 » Sat May 01, 2021 12:58 am
Have a question 2018 transit custom (facelifted model). See when I connect my iPhone with a lead plugged into the usb it doesn’t play the music from my phone. I need to connect via Bluetooth. Is this normal or is there an issue. It’s just annoying as I have my phone and my work phone. If I have mine playing music and my work phone rings it won’t connect to the Bluetooth without me switching the phones in the settings.
Has anyone come across this issue. If so have you found a way around it. It has sync3 non touch screen
Sparkyg1000
Re: Stereo
Postby Altransit » Sat May 01, 2021 10:22 am
Is it because you have the bluetooth on the music phone turned on :?:
I do exactly the same thing as you on my Mk7, except that the music phone has bluetooth turned off, but then my radio is much more basic :!:
Re: Stereo
Postby Sparkyg1000 » Sat May 01, 2021 11:10 am
I have tried it with Bluetooth off and on. Would just make it so much easier if it played with the leed rather than having to connect via Bluetooth as it knocks my work phone off
Sparkyg1000
Re: Stereo
Postby S60r » Sun May 02, 2021 8:29 am
Are you using the top usb above the steering wheel?
Remove the non work phone from the BT list or ‘forget this connection’ in the phone settings?
S60r
Return to Transit Custom
