traction control/wheel speed sensors
Postby ajgelectrical » Mon May 03, 2021 5:21 pm
Hi, i have the traction control light on and engine service light on and van in limp mode. getting p0046-47-48 fault codes, im wondering if the speed sensors are faulty will this show on a reader and could this possible make the van go into limp mode and showing up as a turbo actuator fault instead?
ajgelectrical
Re: traction control/wheel speed sensors
Postby ajgelectrical » Sun May 09, 2021 1:17 pm
sorted
ajgelectrical
Postby Altransit » Sun May 09, 2021 10:54 pm
ajgelectrical wrote:sorted
Are you not willing to share the solution?
It may help the next person with that problem :idea: :)
Postby ajgelectrical » Mon May 10, 2021 1:36 pm
Sorry posted answer on my other question on here, it was the turbo actuator, got it from Turbo Vanes but via amazon £60+£9.99 postage. 30 min job for a novice. Luckily i bought a cheap code reader so i was able to reset fault codes. Not sure why the traction control light was on though. Done about 40 miles and no warning lights and turned hill start back on and that seems ok. You will need to g number to get right part which is on underside of actuator, luckily i have a small camera i use for work so was able to get the number without taking old one off first.
ajgelectrical
Postby ajgelectrical » Mon May 10, 2021 1:38 pm
Other question i put on was about speed sensors, i did disconnect 1and it did come up with ABS fault and did show on fault reader
ajgelectrical
Postby Altransit » Mon May 10, 2021 4:27 pm
Cheers, many thanks :D
Return to Transit Custom
