Water leak middle console to passenger footwell using air co
Postby DIGGER73 » Tue Jun 08, 2021 1:57 pm
Howdy. Whenever I use my air con I seem to get a puddle that lands in the passenger football, which i think comes from the centre console area somewhere. I've got a haynes manual whichbdoesn't help. Google searching hits Transits only. Any pointers would be great!
DIGGER73
Re: Water leak middle console to passenger footwell using ai
Postby Mike » Tue Jun 08, 2021 2:50 pm
The condensate drain could be blocked. MK7 drain was on the bulkhead, someone will probably be able to tell you where it is on the Custom, or you could do a search to see if it’s been mentioned before.
Mike
Wind up merchant!
Postby Marcus123 » Wed Jun 09, 2021 12:25 pm
Had this a few years ago, garage found the A/C pipe was run through the bulkhead against a hot pipe causing consenation everytime I used the A/C, they put some insulation / lagging between the two pipes and I haven't had the problem since.
Marcus123
Return to Transit Custom
Users browsing this forum: drollos
