Chrisp74 wrote:Brahoy, Forscan is a very good piece of sofware, and free! You only need to buy a ELM lead that connects to the van. If your confident, its quite easy to get yourself set-up to look at data.
Frag wrote:I’d suspect a faulty dpf pressure sensor….
It may not generate any dtc,but if it’s faulty,it will show dpf back pressure that’s not actually there,which will ruin soot load calculations and keep triggering a regen…..
Frag wrote:On a ‘16 it’s already years out of warranty….
And he’s changed the sensor,and it halved the amount of regens so not sure about the ‘no fault found’….
Frag wrote:IF it was in warranty we would test the DPF sensor,and replace it if faulty,
But to do this you need a mityvac and at least a multimeter,preferably the ability to data log the sensor,and to know what readings you are looking for.
Most people don’t have that equipment or info so it’s easier to ‘try’ a new sensor…
Which he has,and if regens having changing clearly it was faulty
