Electric Window One Touch Up/Down Function
Postby DeuceTudor » Wed Jun 16, 2021 11:29 am
2017 Transit Custom,
Drivers side window has one touch function for up / down, but it doesn't work for the passenger window, either from the drivers side switch or the passenger door switch. Ford ETIS shows the van has "Power Front Windows One Touch Up/Down" should this work on both sides or is it drivers window only ? Went to my local Ford Dealer and they didn't know !!
DeuceTudor
Re: Electric Window One Touch Up/Down Function
Postby Marky M » Wed Jun 16, 2021 1:05 pm
Mine is a 2018 model (facelift) and it's the same. Only the driver side has one touch up/down.
Ford Transit Custom Sport 2018
* L2H1
* Chrome blue and stripes
* Customised for wheelchair accessibility/driving
* 20" Bola B20 Black polished
* K&N insert filter
* Led lights
https://fordtransit.org/forum/viewtopic.php?f=65&t=189567
Marky M
Postby dumper » Wed Jun 16, 2021 3:10 pm
Every vehicle I’ve driven with one touch up and down as only been on the driver’s side .
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Postby p2thed » Wed Jun 16, 2021 7:36 pm
Only the drivers window
p2thed
Postby Nederbelg » Thu Jun 17, 2021 9:03 am
My advice: change dealer if they can't answer the simplest of questions. :shock:
Gr Nederbelg
Nederbelg
Postby DeuceTudor » Thu Jun 17, 2021 12:57 pm
Nederbelg wrote:My advice: change dealer if they can't answer the simplest of questions. :shock:
Gr Nederbelg
Only stopped in as i happened to be passing, not impressed.
DeuceTudor
Postby DeuceTudor » Thu Jun 17, 2021 1:01 pm
Thanks for the feedback, does any body know if it could be coded for one touch on the passenger side? It was one of a handful of options on my jeep that didn't stop working :roll:
DeuceTudor
Postby Altransit » Thu Jun 17, 2021 1:57 pm
DeuceTudor wrote:does any body know if it could be coded for one touch on the passenger side?
One touch needs an extra relay in the door which holds the power on, so it's not just down to programming.
My Focus has one touch on both windows, so it isn't hard for it to be factory fitted, just Ford being cheap :lol:
Postby DeuceTudor » Thu Jun 17, 2021 8:34 pm
I guess so, :lol:
DeuceTudor
Postby sparkie1984 » Sun Jun 27, 2021 6:48 am
Makes me laugh how Citroen vans have this on both windows yet Ford are so cheap!!
My 2016 connect only had one touch to roll the window down!! So the transit is at least a small improvement
sparkie1984
Postby Jezclayton » Thu Jul 01, 2021 5:12 pm
I thought they didn't put it on the passenger side for safety reasons. My dog likes to stick his head out of that window and he's always standing on the switch.
Current - Custom 300 L2H1 DCIV Limited 2.0 EU6.2 170ps Auto 09/22
Previous - Custom 290 L1H1 DCIV Limited 2.0 EU6 170ps 09/17 (Sold)
Previous - MK7 SWB 140 T280S Limited 2.2 FWD. 03/12 (Stolen)
Previous - MK7 MWB 130 T300 GLX 2.2 FWD. 04/07 (Sold)
Jezclayton
GLX Posse
Postby sparkie1984 » Thu Jul 01, 2021 6:09 pm
That makes sense but why can’t the drivers side have the feature for both windows
sparkie1984
Postby Nederbelg » Thu Jul 01, 2021 8:08 pm
For safety reasons, windows whith "one touch up" funktion, must have "anti pinch" technology. This consists of a current monitoring device which measures the current to to windowmotor. If the measured current goes over an destinct threshold, the window will stop and automaticaly open again.
Clearly this makes the system somewhat more expensive and that's why it isn' t there on both windows.
Gr Nederbelg
Nederbelg
Postby Tobyb » Fri Oct 31, 2025 1:14 am
Ive got a Mk8 Transit and the window switch started to play up so i bought a new one from ebay. However when I fitted the new one it became clear that the one that was delivered was for a left hand drive model as the button on the left that would normally operate the passenger window was a “one touch” and I watched in wonder as for the first time I saw a one touch passenger window on a transit van. Unfortunately the right hand side window was now a poverty spec and I’d lost the one touch!!
Also left became right and so on as the LHD switch I had was technically in the wrong side.
Obviously I immediately took apart my old window switch to see if I could cannibalise it to make both my windows one touch.
Unfortunately, it was the Driver’s window switched that failed in my original switch and no amount of switch cleaner was going to make it work again. The interesting thing was the switches are very different. The passenger side one is a rocker. The other one is on some kind of sensor type. odd looking thing anyway I hope this helps somebody.
Tobyb
Postby Tobyb » Fri Oct 31, 2025 1:18 am
I accidentally bought a left-hand drive switch for my right hand drive transit.
Interestingly, this switch for a left hand drive vehicle made my passenger window a one Touch operation and the drivers Window a poverty spec.
So it appears there is no relay in the door no special wiring it’s all down to the switch itself with that in mind. I opened up my old switch to see what it was like inside there are two very different switches inside the body of the main switch depending on which country of origin it is one Touch works by having a slightly different switch when you open it up you can see that the poverty spec side in either switch left-hand drive right hand drive is a traditional toggle switch working on micro switches. Where is the one Touch switch is some kind of switch I’ve not seen before really delicate working lot on micro switches, but on centre as I think I did wonder could I cannibalise the pair of them to make one switch that will do one Touch on both windows? I’ll update this site if I managed to crack it I hope this helps somebody.
Tobyb
Return to Transit Custom
