So this is our 2015 Transit Custom 2.2 TDCi - 60k miles, last fully serviced August 2020
Van failed to start then came to life, ran for about 10 minutes then cut out again and failed to restart.
Here's what we know:
Fuel filter OK, fuel pump, fuse and relay 100% ok
Ignition on and pressing low pressure valve (A) allows diesel to pump out via valve
Cracking open feed to rail and cranking engine on starter motor shows no diesel reaching rail
When 'Easy Start' was sprayed into induction, van started and ran perfectly for a few seconds on the vapor
See photos
Could it be a pressure valve requiring replacing or something else or is it potentially a full pump failure (!)?
Many thanks for any steer
