by 25joinery » Fri Jul 09, 2021 6:05 pm
After a bit of research on line, there were a number of companies in the South Wales area that fitted van security. I phoned around and asked questions about their method of fitting, what they did to protect any cutouts in the bodywork from corrosion etc.
I used a company called Titan Locks based in Ystradgynlais, who were head and shoulders above the others in terms of how conscientious they were in the fitting process, (the used magnetic mats all around the van where they were cutting, etc so nothing could get rubbed on bodywork, (tools/swarf etc) they Treated and painted any bare surfaces, and made the cutout 0.5 mm larger than the lock body so it won’t rub against the body or doors as they move and flex slightly when driving and they seal this gap with a permanently flexible filler/bonding agent. (Sounded a bit like Tigerseal)
I had high level hook locks, fitted to rear and side door. The drivers door lock had been banged in with a screwdriver so they removed that (which was job on its own because the key wouldn’t go in to it) and fitted an upgraded rep lock (with the larger stainless steel round bezel) and keyed them all to match.
They booked me in, were ready for me when I got there, and it was ready by the time they said it would be. And there’s a guarantee with their work and parts.
So if your in South Wales and need a set of locks look them up. I can’t fault them to be honest.
Just the OBD lock to do now.
