FJ111200 wrote:That's exactly what mine is doing at the moment, same model and year and a 130ps but with only nearly 38,000 miles.
I've booked it in with Ford but they can't see it until 28th July.
What i do to start it, which seem to help, is to turn on the ignition and pump the accelerator a few times then foot off before firing up.
BerkshireVanCentre wrote:Did replacing the fuel filter solve your issue?
Frag wrote:I would recommend a compression test next,given those symptoms.
FJ111200 wrote:Frag wrote:I would recommend a compression test next,given those symptoms.
Managed to get mine seen to on the 10th August at Pentagon Ford and after a compression test which showed up 200+psi on all cylinders except number 2 which was 75psi they asked me for permission to take the cylinder head off, which i've agreed to.
Didn't get a progress report yesterday so will phone them by the end of play today.
What a fook up though on a 38,000 mile engine that i've done 7 oil and filter changes on and still got 6 months to pay for out of a 60 month term. I'm not holding out for much sympathy from Ford UK when i get in touch with them when the van is back with me but i'm going to lay it on thick.
Whatever it's going to cost me i hope it will be cheaper than getting a new van.
FJ111200 wrote:Oh i am pissed off! Just had a call from Pentagon Ford and guess what, my van needs a new engine. Jeesus H Christ have i had enough.
I've asked them for the old engine just in case they are trying to pull a fast one and my next port of call is with Ford UK. Honestly i could fookin' swear. b*stard Ford.
Morris12391 wrote:Hi there. Apologies if this has been covered before have had a fairly good hunt through old posts and can’t see anything.
My father in law has a 66 plate transit custom 2.0 eco blue with 97000 miles that he has kindly asked me to sort out. It doesn’t start on the key when cold will crank and crank until time exceeded but won’t start. Bump start it and run for a couple of minutes and it will start off the key and be fine all day until you leave it for a period of time time then same again. Drives fine, pulls like a train, no rattles doesn’t overheat and doesn’t pressurise coolant. No fault codes present. It’s been in to Ford today for the timing belt inspection recall so I asked them to look at this issue while they had it and they are telling me it needs an engine!! Apparently they’ve had the problem before and the cylinder liners had moved causing the fault. Perhaps it’s me but something doesn’t ring true there. Has anyone else had similar issues? Or come across this liner fault? Any input would be greatly appreciated before I pull the engine over the weekend and start stripping.
Morris
