%20(160%20x%2090).jpg)
Rob14 wrote:hi , no not yet still working on it, P062D AND U0401 invalid data received from PCM in ABS module also , i have no 12v to injectors!, wire harness checking out ok from PCM to injectors no open or short circuits , 200 oms tested on all 4 injectors from PCM and at the injector with wire harness connected and disconnected , also water ingress inside wire harness all cleaned and tidy up and water leak sorted no water in PCM at all by the way i have opened PCM , i am suspecting PCM injector control driver internal failures , van will start after reconnecting PCM but will cut out after 1 min running this is intermittent/ randomly happens , engine malfunction message pops on dash will not start again ,depending were you had the damage on yours what DTC you have? if you have dtc in RCM than maybe is inhibiting engine start by the crash event stored in module , if passenger side was involved in crash than that were is the PCM fitted and ABS same side just below , second hand PCM on his way ill post here with outcome so watch this space thank you ,regards ROB .
