Dual battery's
Dual battery's
Postby Tezenforcer40 » Sat Aug 21, 2021 8:05 pm
Hi Guy's n Gals, I have a new to me 64 plate custom eco tech, is it supposed to have two batteries?
These are pictures of the battery box there seems to be some gadgetry on the fire wall at the back of the box.
I have read some where that they have two batteries the work together on start up but the separate afterwards.
I'm ok with most things but not too confident with electrics, I just want to find out if I have the necessary hardware so I can get an auto electrician to make the connections as there seems to be alot going on in there lol.
Regards Tez
Bubba when I get home Ima gonna whoop your Mamas ass, cos sure as hell you never came from my loins
Tezenforcer40
Re: Dual battery's
Postby sezyal » Thu Aug 26, 2021 8:25 pm
Tezenforcer40 wrote:get an auto electrician to make the connections
What kind of connections? There must be a connector on road side of driver seat to access battery power directly.
You have 1 (ONE) battery. Not all transits have 2 batteries. I have 2014 Custom Bus and I do have 2 batteries which I just changed after 7 years of service. When they are two, one is dedicated as starter battery, other one is for auxillary. My aux battery was 0% (leaking acid) but it was still starting fine as starter battery was ok.
2014 Tourneo Custom 155 SWB Titanium Plus
Stratosphere Blue
+18" Sport Wheels
+HID Kit
sezyal
Re: Dual battery's
Postby sezyal » Thu Aug 26, 2021 8:29 pm
BTW, if you wait until your aux battery dies and keep driving (because you can with 2 batteries), probably you will put too much stress on alternator. I am checking/replacing my alternator now as it doesn't work after driving with totally dead aux battery for more than a year.
Stratosphere Blue
+18" Sport Wheels
+HID Kit
sezyal
Re: Dual battery's
Postby Eveshamhardcore » Fri Sep 10, 2021 4:58 pm
When I bought my van I assumed it had 2 batteries, becuase it had the 3 pin plug, but it doesn't.....
as someone said, yours has 1
Eveshamhardcore
Re: Dual battery's
Postby 5quirrel » Sat Sep 11, 2021 7:30 pm
Hi Guys, If I wanted to install a second battery does anyone know the physical dimensions that are allowed/required in the space next to the first battery under the drivers seat?
Regards,
Stephen
Tourneo Custom 2017 Diesel Bus 2.0 EcoBlue FWD V362 F3 1995cc 77KW 105HP YLFS
5quirrel
Re: Dual battery's
Postby 5quirrel » Wed Sep 15, 2021 1:39 pm
I have based my conclusion on measuring the available space under the driver seat and the existing AGM 80Ah battery dimensions. I believe (to answer my own question) the available size available for an additional battery is 315 x 175 x 190 mm
5quirrel
Re: Dual battery's
Postby Eveshamhardcore » Thu Sep 16, 2021 3:11 pm
keep us informed if you go ahead as I'll be doing the same soon
Eveshamhardcore
Re: Dual battery's
Postby glenandemm » Sun Sep 26, 2021 8:07 am
I fitted twin batteries to my old 2.2 custom, basically just plonked the same size batt next to the existing one and ran two appropriate link wires from batt to batt, didn't bother with the battery monitor sensors although the plugs are there but I think you'd need to change the settings in the bam or something maybe too so I just did the above and ran fine for 3 years while I had it!
glenandemm
Re: Dual battery's
Postby 5quirrel » Sun Nov 14, 2021 7:08 am
Just to confirm things - the second battery is a 100Ah AGM 315 x 175 x 190 mm and it simply drops in place next to the existing 80Ah battery. There is a plastic strip that is used to secure a single battery so just pull that out and drop the second battery straight in.
5quirrel
Re: Dual battery's
Postby hfac1988 » Sun Jan 09, 2022 2:00 pm
5quirrel wrote:Just to confirm things - the second battery is a 100Ah AGM 315 x 175 x 190 mm and it simply drops in place next to the existing 80Ah battery. There is a plastic strip that is used to secure a single battery so just pull that out and drop the second battery straight in.
Hello! Hope you don't mind me resurrecting the thread - how did the cover fit back on after you've put the battery in? Or, did you have to do any further modifications or is it simply a bent plastic cover with a tight fit?
Thank you!
hfac1988
Re: Dual battery's
Postby 5quirrel » Sun Jan 09, 2022 9:20 pm
Hi, the plastic cover that goes back over the top of the batteries prior to the metal retaining bracket is just a think plastic cover, however it does have a couple of small slots underneath at the front that clip/slide/push/hit with a brick over a couple of tabs on the battery holder box.
If you get the angle correct when putting the cover back on then it simply pushes forward and sits nice, get it wrong and it will not seat properly. I found the best thing to do was to feel for the tabs first so you know where they are and then line the tabs up so they glide in.
I agree it can be fiddly, but knowing that should help you get it back in place.
Hope this helps.
5quirrel
Re: Dual battery's
Postby hfac1988 » Sun Jan 09, 2022 10:50 pm
5quirrel wrote:Hi, the plastic cover that goes back over the top of the batteries prior to the metal retaining bracket is just a think plastic cover, however it does have a couple of small slots underneath at the front that clip/slide/push/hit with a brick over a couple of tabs on the battery holder box.
Hope this helps.
Amazing. Thank you. I was planning on taking the seat off to do it as I can't be bothered fiddling in the dark. Should help. :)
hfac1988
Return to Transit Custom
