Transit Custom Paint code???
Postby cyclingspongecake » Sat Sep 04, 2021 6:54 pm
Can someone help me identify the paint code for my 2017 transit custom. I've just looked at Halfords touch up paints and their codes don't resemble anything on the the plate. All I know is that its blue :D I have no clue which of the numbers/letters on the plate is supposed to be a paint code, they dont' make it easy!
Thanks!
cyclingspongecake
Re: Transit Custom Paint code???
Postby Altransit » Sat Sep 04, 2021 9:43 pm
Paint code is usually under the bonnet, on the slam panel. Should be a code, and the name of the colour :?
*EDIT* Apparently, it's not there on the Custom :roll: :oops:
Postby TallPaul » Sat Sep 04, 2021 10:20 pm
TallPaul
Postby Altransit » Sat Sep 04, 2021 10:25 pm
Oh, is there no underbonnet plate on these Paul :?:
Postby TallPaul » Sat Sep 04, 2021 10:32 pm
Altransit wrote:Oh, is there no underbonnet plate on these Paul :?:
Nope, that would be too easy!!
Actually, I'm not sure if I've marked the right code, I cant find anything as B7, this is mine, 2018 ...
TallPaul
Postby TallPaul » Sat Sep 04, 2021 10:46 pm
Could be this I guess, does suggest "B" may be the code in the synonyms list. Blazer Blue, dont think its metallic if that helps?
https://www.paintcolourchart.com/cars/c ... a5103.html
TallPaul
Postby cyclingspongecake » Sat Sep 04, 2021 11:10 pm
Hmm thanks. The only colour Halfords had in their book was I think Deep Impact Blue so I assumed that this was the only blue Ford currently did, but probbably wrong on this. The colour on the lid of the aerosol does look similar but their code was 7289/J4/G which still means nothing. A look online seems to show this same code for the colour and I've just looked under the bonnet and there is no extra plate there either.
cyclingspongecake
Postby cyclingspongecake » Sat Sep 04, 2021 11:18 pm
TallPaul wrote:
Can't find a colour online corresponding to FT on your plate, and B7 seems to be Zinc Yellow so that can't be right. They could have made this easier!
cyclingspongecake
Postby ned » Sun Sep 05, 2021 6:29 am
Put your reg number into this https://www.etis.ford.com/ and it’ll tell you the paint colour.
There must be about 300 blues ford use.
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby cyclingspongecake » Sun Sep 05, 2021 10:18 am
Thanks Ned, that is an interesting web site. Deep Impact Blue it is :-)
cyclingspongecake
Postby Adventurevan » Sun Nov 21, 2021 6:30 pm
Actual location of Ford transit custom colour code is behind the main grill on a metal tag pinned to the crumple bar
I’ll post pics once I work out how to
Adventurevan
Postby Adventurevan » Sun Nov 21, 2021 6:42 pm
Adventurevan
Postby Adventurevan » Sun Nov 21, 2021 6:47 pm
Hi
Theres a tag behind the front grill (behind number plate)
Pictures attached from my 2015 64 plate custom ltd
hope this helps
Adventurevan
Postby Altransit » Mon Nov 22, 2021 8:50 pm
Altransit wrote:Paint code is usually under the bonnet, on the slam panel. Should be a code, and the name of the colour :?
I was almost right then, just a few inches out on the location :lol:
Postby ChromeOrange » Wed Jun 05, 2024 4:49 pm
Adventurevan wrote:Hi
hope this helps
THANK YOU!!!!
ChromeOrange
Return to Transit Custom
